Cant get my newly changed 3.0 to start
I just changed my sons 2000 3.0 engine with a 2001 3.0 in his Ford Ranger. The 2001 was running before I removed it from the donor truck. I broke a vacuum line on the back of the intake manifold when reinstalling so I swapped the intake and throttle body. Everything else was a normal engine swap but the engine will not run. It turns over and will start with starter fluid but will not stay running. Could this be a bad intake gasket, bad throttle body gasket? I swapped the computers incase it needed to be flashed but still no change. Turns over, wants to start but just wont. Any suggestions will be extremely helpful.
Regards,
Keith
Это хороший вопрос?
Счет 0
Добавить комментарий
