2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
265вопросов Показать все
early 2013 MacBook Pro 15 inch
Model A1398 15 inch early 2013 macbook . I have a cracked screen. What screens will work for this? Or is there a way to make a screen compatible with soldering or changing components.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Big Phil The Piper  you’ll need Apple part number 661-7171. This is a beast to change that the display. I suggest you replace the complete assembly. ''MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement
Now could you make another screen fit. Possible but you would need to have the datasheet for your screen and then compare it to the datasheet of other ones. not an easy task to a. find it and b. possibly convert it to meet the requirements. It would most likely cost you more than the complete assembly.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Big Phil The Piper будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 35
