The Samsung GT-C3300K is a budget touchscreen phone released June 2010.
I forgot my phone's password.
I have lost my password, and I can't use my phone without the password. How can I reset the password? Are there any general passwords?
Это хороший вопрос?
Счет 949
180 Комментариев
Wow what a magic
из
i forget my password.so please any on help me to open or format .modal no GT-s7500
из
i forgot my phone lock my phne is a samsung champ G-C3300i and my keypad doesnt want to work
o
из
i forgot my phone lock,my phne is a samsung champ G-C3300i and my keypad doesn't want to work unless i put in the phone lock first
из
my brother I lost my pattern lock for Samsung gt15500, can you please help....
из
Показать ещё 175 комментариев
Добавить комментарий
14 Ответов
Выбранное решение
Try the last 4 digits of your phone number. If you can't remember the number, then the only solution I know of is to remove the SIM card from the phone (if you have one) and enter the number below. This will erase everything on the phone that is not saved to a memory card (if you have one) or to the SIM card.
*2767*3855#
If that doesn’t work, try:
*0206*3855#
Был ли этот ответ полезен?
Счет 325
215 Комментариев:
Waouh! The *2767*3855# stuff worked in my case like magic. Thanks guy.
из
it really worked! thank you!
из
thank u man
u help me a lot
welldone
из
Where do you type in the number??
из
Показать ещё 210 комментариев
this phone issue can be fixed just need to try some steps and that will help you to solve the issue
try restart and reset using the hard reset for any other step visit http://fixingblog.com/my-phone-is-locked... see if this helps you . thank you
Счет 44
5 Комментариев:
bang bang .....it worked , i am glad that I got it fixed
из
Hey I hard reset my phone because of some problems but now it is asking the Id and password which I used at the time of new phone and I don't remember the password neither I remember the number. My phone is samsung prime. Plz help me
из
It's terrific job-thank U very much
из
I ha e tray both code but not working when press # key it ask for password
из
CUSTOMER_SERVICE_PHONE_NUMBER_+1-855-36.9.85.6.5
из
Well, if you tell us the os of your phone, it is better to get the method to reset the phone password, like android or ios.
But, you can also have a reference from: http://www.wikihow.com/Reset-a-Cell-Phon...
Счет 42
48 Комментариев:
dear sir/ Madam
My phone is off when I turn on, it says phone lock, I know the password too, it used to work but when I turned on the last time, its language changed to Persian, Now I enter my password it does not accept more than 4 digits. my numbers in phone book are very important. If I program it, it will remove the numbers. the code that you gave can not be entered, when I insert the hatch key, it says, password wrong in Persian language. the model is GT-E1282T
PLEASE SHOW ME A WAY.
из
i forgot my privacy password
из
i took out the sim and turned my phone on and it is still locked i cant put the codes in cuz it says emergency calls only can u please help me ??
из
my samsung is like 6 years old and only says emergency without hash or pound, just the numbers
из
Pls help me my phone is Samsung galaxy GT 190601 I have forgot my pin of vodacom protect my device so my phone is not working.
из
Показать ещё 43 комментариев
ur meant to take ur sim card off :) then u can dial the number
Счет 37
7 Комментариев:
dear sir samsung ka mobile hai usme phone lock lag gaya hai aur code maang raha hai parantu mujhe pata nahi hai model gt - c 3312r hai kripya karke upaay batayein
из
please help,my is accidentally locked with with a unknown lock screen pin ( the sim unlocking work proper but i cannot go into the phone unless i unlock that screen lock pin. - samsung galaxy grand
из
Hello sir my mobile name is Intel inside tab and I forgot the pattern of my screen lock and I don't have SIM card in that tab then how should I opened the lock
из
Sir I have forgotten my sim lock password and I want to insert a sim but it shows sim lock a... How can I got my sim unlock
из
I try to this method but my mobile continusly telling network busy what can do the next step please tell me
из
Показать ещё 2 комментариев
As simple as that buddy..
Just press volume + key and power key and the key which is in center together...then select wipe data option...and to select the option press centre key...and it will restrore every tg..and u r done...:-)
Счет 20
12 Комментариев:
this option is 100% working,i fixed a friends' HTC which was blocked yesterday,WELL DONE
из
Thank you , this worked for me on my samsung
из
this wont work for me i tried doing that. the "wipe data" option does not come up
из
my phone when I put it on its only showing phone lock I tried to press * it can't what must I do?
из
My phone its showing phonelock I can't press *so pls tell me what should I do ant the other way to unlock my phone
из
Показать ещё 7 комментариев
If you can make only emergency calls, do it, and when call in progress, hold down the unlock button, and tap dial keypad, then write the *2767*3855# code quickly! And now your phone's starting the factory wipe progress... That trick is works! :)
If doesn't, press call button after you type the code in... (Y)
I hope it helps...
Счет 12
8 Комментариев:
111100000%% worked.and the one an only solution of this problem is this one.thanks for your help sir.your method worked for me.
из
didnt work _samsung J500G. PLEASE HELP ME
из
Great solution bro. working fine. However, while typing 3855 it's showing hyphens instead of numbers. But thank you so much for such an awesome solution.
из
Hi, it works.
I want to change my sim lock password but it's still asking for the old password to proceed, the problem is, I forgot the old password. How can I change it?
из
I have a samsunggalxcy sgh t679m and it's pastword numbers lock and u don't rember it please help me
из
Показать ещё 3 комментариев
type first *27673855# then insert # bw 7&3
Счет 9
6 Комментариев:
yipppeeeeee it really works :)
из
where i insert /
из
I have a Samsung mega 6.3 I forgot the password
Please help
из
It's screen password lock , please help
из
из
Показать ещё 1 комментарий
Use this samsung's master reset password pdf
follow link
http://ccm.net/faq/samsung-517#12558
Счет 5
simply hard reset it
vol up + power + ok
Счет 2
1 Комментарий:
I have a Samsung 5 & forgot my 4 digit code how can I get it unlocked
из
first you define which type of your phone OS or iOS....
http://trendblog.net/how-to-bypass-andro...
the above link can help you if your problem match with this.
Счет 1
3 Комментариев:
My Samsung galaxy GT19082 is locked and I can only make emergency calls n my power switch has destroyed.pls help me
из
anyone can tell me that with these codes is memory will be lost ...I means phone memory...I have important applications in my phone and I can't afford removing it...anyone please figure out the way that how to open the password without loosing the memory....
из
i have forgotten my samsung gte1205y pin and i can only make emergency calls plese i need help
из
1. Unlock With Smart Lock
Smart Lock is an Android feature that lets you specify certain conditions that bypass your lock screen security. You'll find it under Settings > Security > Smart lock on most phones, or Settings > Lock Screen > Smart Lock Type on Samsung devices.
If you have an old Samsung phone running Android 4.4 KitKat or earlier, you may have set a backup PIN. After entering your password or pattern incorrectly, follow these steps:
Tap on the Backup PIN option if you can remember it.
Type in your PIN code, then tap Done.
You will be redirected to the Screen Unlock settings to reset the lock screen pattern.
Regards,
Will
Счет 1
*2767*3855#
*0206*3855#
Счет 0
Enter the wrong password until it says wait for 30 seconds, then log in using your Google account and you should be able to unlock your phone or watch a step-by-step tutorial about this thread.
Счет 0
Lots of helpful tips here! Looks like removing the SIM or using the master reset codes works for most Samsung models.
Счет 0
Добавьте свой ответ
sasan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 22
За последние 30 дней: 81
За всё время: 984,798
