Repairing power connection , intrenal
When power cord is connected,no power ,green light does not go on.
Is there an easy fix to this or must I re solder ,on interior of book.
Это хороший вопрос?
Это хороший вопрос?
IIRC that model had known problems with the battery and the power connector. Check the cord with a multimeter to be sure its providing voltage to the computer. If it is you will need to check out and quite likely need to repair or replace the power connector. I am including a link to the guide that comes closest to assisting you with disassembly. Good luck.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 14
За всё время: 882
