Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220вопросов Показать все
Ipad mini 2 button stuck. Rubbing alcohol/toothpick didn't fix.
The home button on my iPad mini is stuck/jammed. I have tried using a cotton swab with some rubbing alcohol on it to clean around it. I also used a toothpick to clean the little track there as well. Neither of these options fixed the jammed button. I am unsure of how to proceed.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
If cleaning doesn’t solve the issue (I would try again with alcohol), then you will probably have to open it up and take a direct look at the Home Button to see what is causing the issue. These devices, while certainly DIY repairable, are not fun to play with so check out the guide first to see if you want to do this. Open up the device first, inspect to understand what is causing the damage and then order the parts you need. That way you can always decide to pursue the repair or not, depending on the cost of parts (this is an old device after all).
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Caleb будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 8
За всё время: 100
