The Nikon COOLPIX B500 is a mid-tier superzoom point and shoot camera. It is sold in black, purple, and red.
43вопросов Показать все
Why is my Coolpix B500 saying “Mode dial is not in the proper position
When I turn on my camera it shows an error message that reads “Mode dial is not in the proper position”. None of the functions or buttons work, even after removing the batteries and turning it off and then on again.
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
It is not recognizing the position of the mode dial, maybe something is loose inside. Has it gotten wet?
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
It has not gotten wet but I dropped it from about 4 feet and it hit the ground. Their is no visible damage but it might just be internal damage
из
well, time to open it then, if you are lucky you might need to just resit the ribbon connectors.
из
Оценка 0
Добавьте свой ответ
Evan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 11
За последние 30 дней: 57
За всё время: 1,739
