Repair and support information for HP Laptops, designed for home and home office use.
1040вопросов Показать все
Blank Screen, Caps lock light blinks 3 fast 2 slow. Need help..?
I have a HP pavilion laptop model: 14- ce0505sa. Was working perfectly. I just bought it a year back. The problem started when Microsoft sent the update. It was booting up frequently and then after a few days when I tried to reinstall windows and clicked restart it went of..and frm then the black screen and capslock light beeps. I thought it's the ram but it works on someone else's laptop. Open to suggestions. Would appreciate it if someone could help me out in this. Cheers
Это хороший вопрос?
Оценка 2
2 Комментариев
Hey
In my case laptop turn on, fan working but no display shown on screen. Only caps lock keep blinking. Tried to change rams, 15 to 20 second press power button after discharge the battery but no luck. Any one has been go through same situation. Once display come then can do something about bios. Tried external hdmi thought screen issue but no luck.
из
Seeing this on multiple HP machines - BIOS/Firmware update install through windows, machine reboots and either beeps or flashes errors. HP won't acknowledge the problem, refuse to admit liabliity. Keep hold of the laptop as there will be a case against them in future. They need to be accountable for every day you can't use your machine/loss of earnings etc. If you contact them, record the call (I recorded multiple calls) and keep a log of the dates etc.
You may be able to force flash the BIOS from USB and get the machine usable, but from experience it has lost the Product ID etc, and unlike other manufacturers, they refuse to release the files to reprogram it (meaning future BIOS can't be installed etc). This is happening big time in 2022/23.
HP wake up, Apple have been made responsible at times for 10 year old macbooks. We're waiting for you HP, Make it right and between you and MS, get your act together. (Posted elsewhere in case HP will try to remove this).
из
Добавить комментарий
8 Ответов
Выбранное решение
What you need to do is boot from the Windows 10 Installation Media that you have.
# Insert the flash drive with the Windows installation files on it.
  1. For other: You can borrow someone else's Windows 10 install media if you need to. You're not installing or reinstalling Windows, you're just accessing Advanced Startup Options.
# Boot from the USB device.
# Select Next from the Windows Setup screen.
# Choose Repair your computer at the bottom of the window.
# Advanced Startup Options will start, almost immediately.
What you are looking for is Startup Repair. Run this a few times until Windows boots up correctly.
There are other options but this is a start. Driver issues could be part of the problem.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
How you can boot in cd or USB with the black screen how can you see that ..bugok
из
@secret identity It was just a first step in troubleshooting. There was no dialogue from the person which is how we know to check thire progress.
из
ha ha .. can't do anything with any Windows, cuz it does not get past the error code (flashes and or beeps !! totally useless info
из
If you want to fix this issue so follow these Steps
Step 1: Power Off your Laptop and Remove the Battery
Step 2: Press Power Button with Window + B for 30 Second
Step 3: Restart your Laptop. after restart your laptop you can see Boot Device Not Found Error.
Step 4: Press Ctrl + Alt + Delete Keys after that press multi time Boot option key
Step 5: Go to Boot Option in Boot menu and Enable Legacy Support and press F10 for Save Setting.
for more information Click Here
Оценка 1
Just disconnect touchpad cable and keyboard cabale and reset bios.
Оценка 1
2 Комментариев:
disconnection the mouse pad worked for me, When i reconnect it same error, disconnected laptop boots. Using a USB mouse works fine.
из
How do i disconnect those touchpad and keyboard cable, im using hp Elitebook 8470p
из
Johnny Terence Rodrigues appears to be a BIOS error. The error indicates embedded controller has timed out waiting for the BIOS to return from system board initialization (end of POST).
 The blinks indicate system board failure on your PC.
 Try restoring the BIOS to default and check if it helps.
 1.    Turn off the computer and wait five seconds.
2.    Press the Power button to start the computer and repeatedly press the F10 key to enter the BIOS setup menu.
3.    On the BIOS Setup screen, press F9 to select and load the BIOS Setup Default settings.
4.    Press F10 to Save and Exit.
5.    Use the arrow keys to select Yes, then press Enter when asked Exit Saving Changes?
6.    Follow the prompts to restart your computer.
More about recovering the BIOS on here
Check here
for more info
Оценка 0
Only get caps lock 3 long 2 short. Esc, pwr+win+b, f10....none of that does anything. Should I start unplugging ribbon cables one by one and try to boot each time?
Оценка 0
2 Комментариев:
I have the same problem 650 g6 ProBook HP laptop tried win+b esc f11 esc any one got luck same three long flash then two fast also num key appreciate any help in advance
из
Take out ram and clean it with some 99% alcohol. and make sure to take out the battery. this worked for me.
из
Оценка 0
1 Комментарий:
100 percent ram problem
из
If this occured right after you did a Windows reinstall, then I would guess either the install went bad or the install media is bad. Best thing to do would be to recreate the install media with a new download from the MS website and start over with the reinstall.
Оценка 0
I had the same problem and i’ve fixed it by cleaning the fans and heatsync and putting new thermal paste.
Оценка 0
Добавьте свой ответ
Johnny Terence Rodrigues будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 19
За последние 7 дней: 116
За последние 30 дней: 486
За всё время: 38,865
