Apple выпустила смартфон 4 ноября 2017 года в двух различных конфигурациях: A1865, A1901 и дала название iPhone X. Доступны варианты с разными стандартами мобильной связи: GSM или CDMA; с двумя объемами хранилища: 64 или 256 Гб; двумя различными оттенками корпуса: серебристый и Space Gray.
1196вопросов Показать все
iPhone X ear speaker not working
Hi, so i got my iPhone X ear speaker not working after the phone felt in water.
At first it worked even though you heard it low and after some days no sound at all!
So i bought a new one and replaced the old one (kept the original flex cable with all the sensors because i didnt´t want to loose Face ID). At first i thought that maybe the solder was not made properly so i check it again and was just fine. All the sensors are working aswell as the Face ID but still get no sound.
Propably not an audio IC issue because the speakers and the microphone works just fine.
Does someone went through this issue? I searched all the web but got no answer for this problem.
Any ideas please?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
Liquid damage can be a tricky repair and it’s usually not practical most of the time. I would try another ear speaker assembly without transferring faceID components just to see if the speaker will work.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thanks for your answer. I'll get another flex cable already with earspeaker and test it. Btw i did the diode test on the board connector and all values seem correct so i'm pretty sure the issue is in the flex cable or in the solder i did in the new ear speaker.
If i fix it i'll give feedback.
из
Got the problem solved! A bad soldering work was the issue! So i cleaned all the solder a resolder it again and now its working fine aswell as all the other sensors including the Face ID! I’ll leave some photos of the flex cable after the cleaning! God knows how i’m happy to have my phone fully working again :D
Оценка 0
Добавьте свой ответ
Tiago Freitas будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 12
За последние 30 дней: 23
За всё время: 2,396
