Back camera glass cracked,water damage,tried repair phone no longer ch
My phone also has water damage, because the glass that goes over the 2 camera lenses on the back of the phone was cracked and some pieces completely missing from it and I dropped it in the bath tub. So I took the phone apart following the teardown on here
I have everything but the front screen taken off because I have cracks in the corner...so if I take if off it will need a complete screen replacement. Anyway I have cleaned off the corrosion, but I'm not sure how to check and see if anything is shorted out. When I try to put it back together though it doesn't turn on and it's not even registering when I plug the power cord in. When I cleaned the water out of the inside of the phone there actually wasnt even.much water in there so I'm not sure what the problem is. Any suggestiolns?
Это хороший вопрос?
1 Комментарий
kirstinx how did you clean it? Remember' with water damage it does not matter how long and how much, but where it shorted out.
из oldturkey03
