Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1697вопросов Показать все
KitchenAid - krfc704FPS00 - won't cool
My KitchenAid - krfc704FPS00 stopped cooling in the fridge and freezer Sept. 9th. I’ve had the appliance people out twice so far with the last one coming yesterday. Still not cooling.
First time they replaced the compressor, didn’t work, said that there was head pressure that burned it out?
They’ve replaced the compressor, a board, the evaporative coils, took out all the freeon, put in new freeon, he was fusing things with his blowtorch. I had hope, but this morning nothing, not any cooler.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Did he replace the fan in the freezer
If the fan isn't working, it won't
Did he check the thermostat
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Faust Gorham будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 234
