Why is iPad constantly rebooting post battery replacement? See video
Problem: iPad Mini 2 just turns off seconds after turning on and then continues to reboot. At each alternate reboot the screen flashes red before shutting off and turning on again. Please see the short video. It shows me turning the iPad Mini 2 on and shows the iPad rebooting several times.
I am able to turn off the iPad Mini 2 by holding down the power button.
Context: I just replaced the battery of this Wi-Fi only iPad Mini 2.
Possible Useful Info: This iPad Mini 2 was repaired previously. When I opened it up the LCD Shield was bent and screws meant to hold down the LCD Shield actually went through the the metal LCD Shield.
When I received the iPad the battery was completely swollen and had lifted the front screen aka digitizer and did not turn on.
The owner of this iPad Mini 2 was not 100% sure it was a battery issue although seemed like the likely culprit.
My thanks to the iFixit community for your help.
Update October 26, 2020:
- I’ve added photos of the motherboard. Both as it was when I installed the battery and then after taking out the motherboard itself.
- Additionally owner did say that the reboot cycle with the red screen did occur before the iPad died from a bad battery. It had a charge battery signal with the constant reboot, so they thought it was just a battery issue. Obviously it was not.
Это хороший вопрос?
3 Комментариев
Do you by any chance know the OS it has? I recall that there was a bug on some version of iOS 10 that caused some devices to constantly restart itself on boot like this (had a 5S with the same processor do the same, ended up restoring and updating it to iOS 12).
I doubt it would be a problem with the LCD shield since if it was indeed faulty atleast you would've seen something other than the apple.
из amatsuda
Amatsuda, The owner does not remember what version of iOS. They haven’t used it for at least a year
из Eddie de la Rosa
@edd1e I guess that was at my fault. Realized it wan't even an issue with the software (techincally).
из amatsuda
