home button works but new digitizer doesn't
I’ve recently change a digitizer on my ipad mini 2 and the connectors look in good shape but i have a working home but no touch does anyone know why and what to do to fix it
Это хороший вопрос?
Это хороший вопрос?
@ragecage005 could be a bad digitizer but you do want to double check your work. Make sure that the flex ribbon cables are properly routed, seated and not torn etc. Check the connector for bend pins etc. If all of this checks out okay get a new digitizer. If it should still fail you may have issues with the touch IC on your logic board which would require the help of somebody the does board level repairs
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 13
