MSI GT80S 6QE Wont boot up
I was playing a non-intence graphics game and my screen went black. I held the power button to turn off the laptop and when I turned it back on the screen stays black and after about 30 seconds the fans go to 100% speed.
I have tried to use a HDMI cable to see if an external display would work. No change
I have tried to hold the bios reset button for 30 seconds then power it up. -No change
Tried to swap out all 3 ram dims and one at a time in all slots. - No change
I have tried to remove the Sabre HiFi sound card. - No change.
I sent the laptop to MSI but they said it was a motherboard issue and they would not fix it. Does anyone have any suggestions? Thank you
Это хороший вопрос?
Hi Rob
Any reason why MSI do not want to fix it?? out of warranty
it seems to be a mainboard issues from the info you had given.
из Augustine
They said they can't get the parts to fix it and that they think its the MOBO.
из Rob
Hi Rob
if it is still under warranty, it is not acceptable to say there is no parts for replacement.
Else need to perform a board level component repair which is very challenging.....
из Augustine
It's 4 years old so they say it's out of warranty
из Rob
