The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
313вопросов Показать все
Why is my fan is always running at 7200RPM
My macbook fan is always running at 7000-7200 RPM. From the moment, I press the power button, it starts running very loud, and stays the same. It doesn’t matter what I am doing, it always stays around 7100RPM. I’ve reset de PRAM and the SMC. I’ve installed Fanny and it says:
Fan: #1
Current: 7104 RPM
Min: 1200 RPM
Max: 6500 RPM
Target: 1200 RPM
CPU: 34.75 degrees celcius
GPU: 36.00 degrees celcius
Please help me fix it, the sound of 7200RPM is very loud and annoying.
Update (11/04/2020)
Here is the screenshot.
https://pasteboard.co/JyPPvth.jpg
Please let me know if it doesn't work
Это хороший вопрос?
Оценка 1
7 Комментариев:
Did you try running the onboard diagnostics to see if an error code? Restart the system and press the D key to enter. Tell us what it is.
Reference: Mac startup key combinations
из
@danj Thanks for your help. I have already tried that and nothing comes up.
из
To be clear you don't get any errors Or it doesn't work?
из
Pardon me, I don't get any errors. Sidenote: I've already replaced the thermal paste and cleaned the fans thoroughly.
из
OK, lets do this, kill Fanny and install this app TG Pro it will offer a better view of the thermal sensors.
из
Показать 2 больше комментариев
Добавить комментарий
1 ответ
Here’s the needed part MacBook Air 13" (Late 2010-2017) Fan and here’s the guide MacBook Air 13" Early 2014 Fan Replacement
MacBook Air 13" (Late 2010-2017) Fan Изображение
Продукт
$29.99
Был ли этот ответ полезен?
Оценка 0
3 Комментариев:
So do you think it's just a faulty fan? Could a faulty fan choose for itself to run 7200RPM? I would've thought the fan would only follow instructions from the motherboard (like the motherboard would say go run at 7200RPM)
из
Well ... It does get told to speed up and slow down but what if the information to the logic board on what the fan speed is is gone? Think what would happen if you lost your speedometer in your car. What do you tell the police officer when you get pulled over, here the system is designed to assume the worse and ramp up the fan to make sure the system is being cooled.
из
Thanks for your help, I will order in the new part and let you know if my problem has been fixed.
из
Добавьте свой ответ
Tom будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 504
