Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Audio Works But No Picture
Title says it all. When turning the tv on, the audio works but video does not. Have tried unplugging and plugging hdmi cable, swapping out for a different hdmi cable, and have tried unplugging and plugging the coaxial for the cable box, nothing works.
Это хороший вопрос?
Оценка 0
Комментарии:
Hi @tamrielbound ,
Can you view the TV menu screens OK?
Have you tried a different signal source, e.g. a dvd player and checked that it works OK when using it?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hi @tamrielbound ,
Can you view the TV menu screens OK, you didn’t say?
If you can’t see an image when trying either of the above, with the TV on and audio heard, shine a torch at an angle close to the screen and check for any images. They will be very faint if they are there so trying this in a darkened room may help to see them if they are there.
If you can see images then there is a backlight problem with the TV
Был ли этот ответ полезен?
Оценка 1
Комментарии:
I can not see any images such as the menu screens. I tried several different hdmi cords, I tried a DVD player and a blu ray player. The backlight is working, you can see it go on and off with the tv. The backlight also flashes when I hit the Netflix button on the remote.
из
Describe tv model and to where you are connecting the cables.
Оценка 0
Комментарии:
TV is the LG 43UK6300PUE and the hdmi cable is connected from the cable box to the tv.
из
And the cable box, is it connected to the dish? Then, you call the cable provider to set it at your place.
из
Добавьте свой ответ
Charles Jackson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 34
