Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
430вопросов Показать все
The memory I purchased does not work very well.
The memory I purchased does not work very good. Neither one works alone or in tandem. The only way they work is if I use one of them with the Apple memory that came with the iMac in one of the slots. I mixed and matched several times so it’s not like I’m seating them incorrectly.
So instead of 4gig with the two I bought, I can only get 3gig.
Thank you
John Coffey
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Depending on your exact model as well as your OS-X version 3 GB maybe the limit!
The White iMac’s need to be running the OS X 10.7.5 and you needed a firmare update. Its been awhile and I don’t know which one was the needed version.
Locate your exact system here EveryMac - Lookup plugging in your systems S/N. Then tell us which is yours.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
SV In Like Flynn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 20
