iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467вопросов Показать все
iMac backlight failing after teardown.
Hi!
I did a fully teardown on my iMac to clean it. After all when I placed back the LED screen, I saw that the 593-1049-A screen cable almost break. Right I tired to turn on the mac. No screen, just backlight. I said it should be the bad cable. I ordered one, and placed it well. The problem is the same. No screen just BACKLIGHT. And I now use the Mini display port thats works. So any ideas?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
A common issue in this series is tugging on the LVDS cable can damage the logic board socket as the cable length is on the short side.
Carefully open the system up again and take some nice sharp pictures of the connector so we can see if its damaged and post them here for us to see Adding images to an existing question
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Zalan будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 48
