27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
152вопросов Показать все
Why is my display making my room lights flicker?
My Thunderbolt Display recently began making a buzzzing noise. The buzzing starts soon after it’s plugged into my MacBook Pro 2019 ( but not immediately) then after about 3 minuets (sometimes longer) the lights in my room begin to flicker. As soon as I disconnect it from my computer, and the screen goes blank, the buzzing stops and the lights stop flickering. I’ve tried plunging the Display directly into the wall, vs the power strip, into different wall receptacles, and into different ports on my laptop, no change. Also, this did start after updating my laptop to macOS 11 Big Sur. Lastly, I’m running three 27” Thunderbolt Displays and this is only happening to one of them. Thank you in advance.
Update (11/17/2020)
After doing some reading, I'd like to add, decreasing the screen brightness lowers the noise and I'm not using the Display to charge my MacBook and there is nothing else plugged into the Display via USB etc...
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I think you are facing a power issue within your buildings wiring! You’ll need to get a AC outlet tester 3-Wire Receptacle Tester here’s more on why A MUST HAVE TOOL - The Electrical Outlet Tester - How to use and why you should have it I’m suspecting you have a hot ground!
The other possibility is the Thunderbolt display power supply has a short to ground.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Thanks Dan. However, due to this happening when plugged into different wall receptacles, AND the other two monitors aren't making the lights flicker, narrows it down to the one monitor and not the wiring. But, to be sure I did test all my receptacles with my Receptacle Tester and they are wired correctly. Now, question is what component on the Display is causing this? Power Supply, Power Cord, Thunderbolt Cord...? BTW, this issue didn't present itself during 10 hrs of use yesterday. Thanks again.
из
@oikanamas - That points to a power supply is failing.
из
Добавьте свой ответ
David Meyer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 81
