Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
Battery issues - Health stuck at 100%
I got my Iphone 7’s battery replaced about 7mo ago, as I cracked the screen, and the guy said it was only really worth his time to do both, plus I needed it anyways (Bought this phone refurbed) This was all before I had ever taken apart a phone, now I have. I feel like I should replace it, as the battery health is stuck at 100%, 3utools doesnt give me a health or a manufacturer either. I wonder if this is a bad battery, and if I should replace. The battery life has been not great, I now have to charge it 2x a day, after the IOS 14 update. Is this battery bad, and should I replace it? Would this fix the many crashes and freezes I have while using this phone? I suspect it may, but IDK. Thanks for your help!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
If 3uTools doesn’t display the battery info there are usually 4 possible causes.
1.       Faulty battery.
2.       Damaged connector.
3.       Nudged component near the battery connector.
4.       Faulty charging IC usually Tigris.
Batteries are not that expensive and most times fix the issue.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Dylan Devries будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 1,358
