Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Phone won't recognise ew battery
I tried to replaced the battery in my wife's iPhone 6 - I've successfully replaced lots of iPhone batteries in the past - but when I tried to turn the phone on, nothing happened. I plugged in the USB charger and the Apple logo showed up for about 10 seconds. Then the Apple logo disappeared for 10 seconds and 10 seconds later it reappeared. It just kept cycling like that without end. Clearly, the phone was not recognising the new battery. I removed the new battery and noticed that there was too much wire/lead to cram into the small space between the battery and the board and to properly seat the connector in its receptacle on the board - it never snapped into place like the other connectors. Also, I noticed that the new battery's connector was somewhat thinner than on the old battery and it was probably impossible to seat it into the receptacle on the board in such a way that it would make proper electrical contact with it. I re-installed the old battery and the phone works just fine except that the old battery won't hold a charge for more than about 24 hours, even if Wi-Fi and Bluetooth are off and there are no incoming or outgoing calls made with it. Does anyone have any suggestions? Should I just try and buy a battery from a different source other than IFIXTI? What sources do you recommend? Thx!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
I would contact ifixit support and get a replacement. I know what you are talking about and it doesn’t matter where you source the battery from you will always get the odd one like this.
When I encounter ones like this I squeeze the logic board connector with tweezers than connect it, put the bracket on than install the battery into position.
 I always check before I put the adhesive on the battery now days as this is becoming more frequent.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I tried everything, but since the connector on the battery can't go far enough into the connector on the board, there's no electrical connection. Re. the adhesive - unfortunately, I couldn't do a trial installation because the protective shipping strip that keeps the adhesive from sticking didn't allow me to place the battery into such a position that I could get the connectors to make contact. However, IFIXIT has offered to ship me another battery so I haven't given up yet. Also, the old battery seems to have recovered, holding a charge for three days now. Maybe it was the monitor circuit/software that needed the battery to be disconnected and reconnected to reset the battery history and condition monitor
из
Добавьте свой ответ
Thomas Daniel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 103
