My battery only charges if I unplug/plug from logic board
Hi everyone, greetings. Sorry for my bad english. I will try to explain my problem as well as possible.
The last tuesday my MacBook was working correctly until the night. Then, I disconnect it from power cord as usual I do. Well, the next morning, I connect the MagSafe to the MacBook, and it wasn’t charging! I thought: - maybe it´s the plug -, so I tried another one, but the same thing happened. So, I opened the bottom case of the MacBook to look for something wrong with the AC jack on the logic board, but I can’t find anything. Also I tried to disconnect the battery, press the power button for 10 - 20 seconds and reconnect the battery, but it didn’t work. Then, disconnect the battery again, connect de MagSafe and surprise! After a few seconds, the MagSafe led turn on, first green and then orange, and the computer turned on by itself. I repeated this 3 times and it worked the same. So I thought: - what will happen if I connect the battery after the MagSafe? - I tried and again surprise! The battery was charging as usual.
However, if I disconnect the MagSafe, I need to repeat this process, but yesterday I disconnected / connected the MagSafe 5 times and recognized it all. So I let the battery charge to 100% and it did it without problems. Then I disconnected / connected the MagSafe and it didn’t recognize it again, but hey! It was already charged and that calmed me down a bit.
So, the problem:
If I connect the MagSafe with the battery connected to the logic board, it doesn’t recognize the MagSafe and doesn’t charge the battery. On the other hand, if I first connect the MagSafe, the machine turns on by itself, and then I connect the battery, it works perfect.
What is the problem? Will the battery need to be changed?
Note: the battery in this MacBook has never been replaced. It has 888 cycles and the condition according to System Information is normal.
Hope you can help me, thanks in advance.
Update 1: Here is a screenshot of the coconut’s main window
Это хороший вопрос?
2 Комментариев
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
Yes, it does sound like your battery has failed.
из Dan
Thanks for your answer Dan. The screenshot is already uploaded (this capture is with the charger connected; again it does not recognize it).
из Kevin
