Is there an easy way to flash back to an older BIOS after updating?
I have an old GIGABYTE GA-X79-UD3 motherboard that I wanted to upgrade the RAM on. I purchased the RAM that I wanted and it was on the AVL for this board. Popped it in and it would boot but always got errors and BSOD. Ran MemTest and all was good with the ram. I then looked for a BIOS update thinking it might be that and found one then flashed the update. The flash went fine but didn’t fix the Ram issue so I used that ram in another computer. The only problem is everything works fine and the computer boots, but it takes 3-5 minutes to get past the post screen before booting to Windows. Not sure why this happened but I just want to go back to the older BIOS that worked and booted fine. When I try to flash the older BIOS it says it can’t flash an older version. Is there an easy way around this? Thanks in advance.
Это хороший вопрос?
