Why does my Logitech G930 Headset sometimes disconnect and reconnect?
I’ve had this headset for a few years now, and they work well, but I’ve had this problem ever since I’ve owned them. About 2-3 times per game session, the headphones will disconnect and I won’t be able to hear anything or use the mic. After about 5 seconds of no sound, there will be a beep and then headphones reconnect and work as normal.
It’s not that I’m out of range, as I’m right next to the computer and usb stick. Would love to stop this from interrupting my games. Thanks!
Это хороший вопрос?
1 Комментарий
Outside of making sure you are on the most recent version of the Logitech software, my guess is they have a fault component. The best way to test this would be to plug them into another PC, install the logitech software and see if you get the same issue. If the issue continues its a problem with the headset.
из Aron Allison
