Can't reseat motherboard connector after battery replaced
I was following these instructions iPhone SE Battery Replacement and nowhere did it say to be careful not to remove the connector that could be confused with a screen connector as I did. Now, no matter what I do I can’t align and reconnect it. How do I reseat it as its likely a bit twisted due to cable tension and also off centre. These things are so tiny. Its the connector centre left above the lower left screw. What tool and technique would help?
Это хороший вопрос?
2 Комментариев
If the battery isn’t stick to the backhousing already , I usually first put the battery connector in and then position the battery in its place at the backhousing .
из Leslie Leslie
The issue is alignment of the connector. Its not a battery connector its from the motherboard.
из Rusty
