Repair guides and disassembly information for Asus Republic of Gamers G751 laptops released from late 2014 to early 2016. Related model numbers: G751JL, G751J, G751JM, G751JT, and G751JY.
29вопросов Показать все
Asus G751JY Laptop won't power on (no lights)
Model: G751JY-T7094H
Hi,
The laptop stopped suddenly while in use and since I couldn’t start it again. No lights on even when plugged in. I tested the power supply and the multimeter indicated 19.5v as expected. I also tested the battery (not sure though if it is meaningful) and the expected voltage was what I read. I replaced the CMOS battery (I don’t know if this was necessary).
I need some guidance about what to replace. Which tests can I perform to identify the culprit? A new motherboard is pricy. My battery is old (5 years with daily usage), can a dead battery prevent the lights from turning on and the laptop too? Is it the DC connector? How can I know?
I hope someone can help.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Dead batteries can leech enough power to keep a laptop from starting. You can firstly try removing the dead battery and then starting it from the outlet power.
If there is sufficient electrical connection, the multimeter will beep, or else it would probably mean that power cords are faulty.
Otherwise check out these methods and if any of them works.
https://www.minitool.com/data-recovery/p...
Please keep me updated, thank you!
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Thank you for your time and aswer.
People already reported that the laptop won’t start with battery disconected:
https://superuser.com/questions/1237751/...
https://rog.asus.com/forum/showthread.ph...
Nothing relevant in the provided article though.
из
@jpfroud Sorry it didn't help, but please do keep update the latest progress.
из
jpfroud, failures like this are difficult to diagnose. You would need a schematic and board layout to determine what is going on. I suggest that you start off with replacing the battery. Should further troubleshooting be necessary you will at least have a known-well starting point.
Оценка 0
Добавьте свой ответ
jpfroud будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 8
За всё время: 590
