2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
263вопросов Показать все
Black screen : LVDS cable replacement?
Hello, I own an early 2013 MacBook Pro Retina 15-inch. Last week I used a rotary tool to remove two stripped T8 screws so that I could tighten my loose hinge. While proceeding with the tool, I accidentally hit the LVDS cable which was close. You can see the extend of damage here:
https://imgur.com/1e6YgkW
Since, I have a complete black screen with no backlight. The computer is starting, I hear the startup sound but nothing is showing. Could replace the LVDS cable fix this problem? Or could it be something else?
There is also this strange thing, when I plug the charger into the mac, it automatically starts with the start up sound, I don't have to push the power button. I didn’t have this issue before.
Could it be a logic board problem or could it be the LCD display itself ? It would be a nonsense to replace the LCD display of a seven-year-old computer even though it’s software still runs perfectly.
Thank you in advance.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
You do have a bit of a dilemma!
Clearly the cable is damaged and if you tried using it you could have damaged things within the logic board. So you’ll need to make the effort to replace the display cable. You should be able to replace the cable from the bottom its tricky, but doable!
Here’s a view of the displays construct MacBook Pro Retina Display Teardown
After removing the display assembly following this guide: MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement Reviewing the teardown you’ll need to carefully remove the antenna unit per Step 5. And here’s the needed part 13"/15" MacBook Pro Hinge Left - LVDS Cable
Given the systems age you may need a new battery which can explain some of your issue MacBook Pro 15" Retina Display Early 2013 Battery Replacement
MacBook Pro 15" Retina Display Mid 2012 Изображение
Инструкция
Сложность:
Модерировать
MacBook Pro 15" Retina Display Early 2013 Display Assembly Изображение
Инструкция
Сложность:
Сложно
1 - 2 hours
MacBook Pro 15" Retina Display Early 2013 Battery Изображение
Инструкция
Сложность:
Сложно
1 - 2 hours
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
lemineur16 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 273
