The Kingston HyperX Cloud II Gaming Headset is a headset designed by Kingston. This device comes with a headset, removable microphone, and an inline USB audio controller and is compatible with most computing devices. Model number: KHX-HSCP-RD
Lost audio in right ear, suspect wire going into headband
I have high suspicion that the problem lies on the circled part in the image. I’ve nudged the wires around and found out that a brief moment of audio comes back when I ‘push’ the wires together around the circled area.
Is there anything I can do to fix it?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
I got the solution from reddit, I followed it after watching some videos about wire splicing
  1. Cut the cable in half at the break.
  2. Stripped the fabric outside of the cable, 1.5 cm on both sides.
  3. Striped the inner black insulating cable, about 1cm
  4. Seperated wires, one green, one copper NOTE: remember the green ones!
  5. Slightly untwist the ends of the metal wires
  6. Using a lighter, light the tips of the exposed wire NOTE: first time it will catch on fire and run up the cable, blow it out before it reaches the black insulated part, green colour will fade!
  7. Repeat 6 about 3-4 times. Alternate wires. STOP if you see small balls forming at the end of the wire. Never hold the fire on it for more than 2 seconds
  8. Combine green and copper wires back into two neat bunches
  9. Twist both ends with the right colours of the other side side
  10. TIGHLTY wrap with seperate wires once with electrical/insulating tape
  11. Test headset
  12. Wrap another layer of electrical/insulating tape around the two newly connected wires, combining them
  13. Re-assemble headset
  14. Hope this can be of help to people
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Yu WEi Tan будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 2
За последние 30 дней: 19
За всё время: 499
