Полная разборка и инструкции по замене для оригинального iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s и iPhone 6s Plus.
36478вопросов Показать все
Why can't I get my phone or mail app to open?
I had my iphone plugged into my MacBook Pro to sync with itunes but then it asked me to update to the newest version of iTunes.
I did update and downloaded the new version, however my iphone stayed plugged in.
When I re-started my Mac I then unplugged the iphone and it was unable to access any of the data from the Phone tab or Mail or even Settings.
I can get Message from im, and I can access the iPod app.
No sure if I should try to unscrew the phone and take out the battery like I used to do on my old Blackberry...
Help!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Have you updated to iOS5 as well as have iTunes 10.5? You will need both versions of equivalent firmware on both your Mac O/S and iOS in order for your iPhone to work properly.
When it comes to ANY firmware related issue, the first step is to update/restore. Make sure you have upgraded to iOS5. Don't worry about losing any data because it is all backed up before the update, however i am 99% sure that this will fix your problem :)
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Mary OConnor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 357
