Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
105вопросов Показать все
How to remove the digitizer (no glass) from OLED panel?
I tried to do a glass-only repair and remove the OLED+digitizer+polarizer from the (cracked) glass instead of removing the digitizer+polarizer+glass from the OLED panel. It didn’t go well… I have a polarizer (I think) that’s flaking off and a small bubble imperfection on the edge of the digitizer. The display and touch both work, but I can’t reassemble it this way. Photos attached.
How do I remove the digitizer from the OLED panel without ruining the OLED? I tried heat once and it burned the OLED, presumably since there was no glass to act as a heat sink. What’s the best way to do this? I really don’t want to ruin the panel… they’re so expensive. Thanks in advance!
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
I ended up *very carefully* separating the digitizer from the OLED panel by using a 0.05mm molybdenum wire. Lots of glue rolling ensued. Now I have a fully functional bare LCD/OLED panel. Ordered a new glass with digitizer and then I’ll be set.
One YouTube example used a hot decal scraper and that was just too scary for something so small. No thanks.
Был ли этот ответ полезен?
Оценка 0
Sadly I have not found anyone with the needed skills or tools to replace the watch crystal reusing the panel without having visible defects. In the end I just replaced the full assembly.
Оценка 0
Добавьте свой ответ
J.R. будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 132
