Repair guides and disassembly information for the MacBook Pro 16'' released in November of 2019. Model A2141, EMC 3347.
Replacing JUST the keyboard of the 16" MacBook Pro
With Apple switching back to the keyboard mechanism used in the 2015 Macbook Pro’s, I figured it might again be possible to replace the keyboard without replacing the entire top case. I have a Macbook Pro 16” with a defective arrow key, and sourced a new keyboard on Aliexpress for $30.
I took it apart, carefully removed the keyboard backlight (there’s a flex cable covering the ESC key area that needs to be disconnected first) and removed all visible screws - 20 or so. The rest of the keyboard is held in place with rivets, just like the 2015’s. I pulled out the old keyboard (using pliers), and then tried removing the left-over rivets. However.. That doesn’t appear to work: removing the rivets does not leave holes where you can then screw new screws in. Instead the rivets simply break off.
Thus I simply put the new keyboard in place, and used a dab of superglue on every rivet. To keep the keyboard pressed down I needed something heavy that wouldn’t cover too much of the keyboard, and settled on AA batteries - see the attached picture. I’ll assemble the Macbook again tomorrow when the glue is fully dry and report the results.
Update (12/30/2020)
I put it back together today and it works perfectly. So this post is just for anybody on Google who wants to know if it’s doable to replace just the keyboard on the 16” Macbook Pro - yes it is.
Это хороший вопрос?
Счет 2
4 Комментариев
Super Glue has its limits! Over time I'm sure some areas of your keyboard will feel spongy as the spots become loose.
из
Do the left over rivots need to be removed, or can I keep let them be? Has the super glue held up?
из
Hey, wondering how this is holding up long term. I got the same issue here. I tired ordering screws online, but haven't had any luck. Ones I got were too small. thinking of just gluing it at this point.
из
Performed this repair some months ago on a 2019 model. I did not remove the rivets entirely, but did smooth out and shorten them somewhat with a Dremel. They were quite pointy after ripping off the rivet heads.
The glue is still holding up, and hopefully will for at least another two to three years.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
You do know that this keyboard is covered under an Apple Replacement program:
https://support.apple.com/keyboard-servi...
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
It's not, the 16" is not in the list of models that you linked.
из
@iphone3ghulp - You're right the 16" model is not. Even still I would have brought it in and have a good heart to heart talk with the genius and anyone else up the food chain to get it fixed under a warranty exception!
If the scissor key was the problem then you could have replaced it alone Scissor Clip - Arrow Keys (Type-R)
The older 2015 models could have the cup replaced which is the part that creates the short across the contacts. You might have been able to pop off the keycap and the scissor mech to gain access to it Type-J Silicone Dome I haven't attempted to fix the newer butterfly or magic keyboards after seeing how hard they are after tearing one apart.
из
still the same - Apple can only offer to replace the top case for a single keyboard key fix! All at your expense! The "genius' told me that I could use the other shift key (the left shift key is the problem with my 2021 MacBook Pro) Can you believe that? A key goes out on a $2400 computer and they suggest to use the other shift key?
Apple has really fallen from the great company they once were.
из
Добавьте свой ответ
Cero буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 19
За последние 30 дней: 117
За всё время: 3,719
