Status LED Description
Green (blinks slowly) Charging normally
Off Charging finished
Green (blinks quickly) Error
I would suggest to use a AC charger and not the USB from a computer. If your battery is discharged to low the USB port will not supply enough amperage to charge the battery. I would definitely start with a new battery, and an external charger. That way you know for sure what works, especially since this is a "refurbished" camera. You could look at places like this for your parts. Good Luck
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
