HP doesn't accept input from HDMI/DisplayPort Cable, but does from...
I have an HP ProDisplay P202.
I can connect my MacBook A with USB-C using <USB-C to DisplayPort cable> and use the monitor, but the following doesn’t work:
Macbook A to <USB-C Vava HUB> then <HDMI to DisplayPort Cable #1>
Macbook A to <USB-C Vava HUB> then <HDMI to DisplayPort Cable #2>
Apple TV with HDMI using <HDMI to DisplayPort Cable #1 or #2>
Macbook B with HDMI using <HDMI to DisplayPort Cable #1 or #2>
I can’t figure out what the issue is since monitor works with one cable, but not HDMI cable - is there something about HDMI to DisplayPort that prevents it from working correctly?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
From what you have described I would say it is probably the HDMI cable that is the problem. Have you tested it on another system? Just curious, why would you want the HDMI cable over Display Port? It is like beer and champagne.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Melvin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 213
