[GBC] game won't boot, cartridge works fine with an other GBC
So I recovered an old gameboy and changed the screen that was broken. The process seems to have succeeded as I could see the Game boy logo upon turning on the device.
I tried it when a Pokemon yellow cartridge but the game won’t start. I have a blank screen without sound. I tested this same cartridge with an other GBC and it works fine, which means that the problem doesn’t originate from the cartridge.
I tried to look at the pins in the cartridge receiver of the GBC, but it also seems fine.
Does someone have encountered a similar issue ?
Thank you in advance for your help.
Это хороший вопрос?
did you end up fixing it?
из James Gallien (B82ries)
Does the GBC itself work with other cartriges?
из Markus Norstrøm
@jamesgalli33407 looks like teh last time Marko Stojanovic was here, was 3 years ago. You might get a better response if you create your own question if you have trouble with your GBC
If you are just asking out of curiosity reason, then I hope the OP will get back to you soon.
из oldturkey03
