iPhone 8 slow when connecting to charger - and ok when not connected
Hi there,
I got iPhone 8 on iOS 14.3 .
I got weird issue with it - it is fine till I connect it to charger - when it become slow when wake up - then to make it “fast” again - I have to reset it (volume up down power button).
It is not liquid damaged - display is Apple BUT - it has “new” non Apple battery .
What do you think - is it battery problem or mother board or……. iOS 14 as other people complain about it
Thank You
Bart
Это хороший вопрос?
are you having this issue with more than one charger or just a certain one? Where did you get the battery and did this start to occur after the battery was replaced?
из Jesse Hooton
yes - after replaced - and battery was NEW and reported 100% original capacity.
I've replaced it with other NON-Apple battery and - so far few hours and it is fine.
Hope it is not temporary fix like with other battery - where after reset - iPhone was fine for less or more 1 hour
из Bart
@Bart ok but where did you get the replacement batteries from?
из Jesse Hooton
@hootonberg from eBay.
And iPhone is fine till this day
из Bart
@hootonberg
1. If there is something wrong with battery - you got 30 days to FREE return and get FULL refund - no questions asked.
2. When I hear higher capacity battery (than original" I just know they are...... SCAM!
I know too much about batteries - there had to be somewhere sacrifice somewhere in producing them - as they would NOT fit into iPhone.
So sacrifice could be done with less protection / insulation or terrible battery motherboard BUT they usually give you standard size battery with printed random capacity with flashed that information (I know how to use iCopy Plus to flash this) BUT THEN......... you are charging battery MORE than it can handle and........ you end up in news because you were so stupid to believe in LIES and you blame Apple for your own stupidity :(
из Bart
Показать 3 больше комментариев
