Funky display, external monitor doesn't work
Display used to work, now can’t see anything but colors are visible in cracks (see image). Want to replace display. Hooked to my TV via Tb3 port and Tb3—>mini-display connector—>HDMI. NO image on TV, not even the lines I can see on laptop (see image) and TV says “no signal”.
Will this machine not display on my HDMI TV? I’m concerned that this mean something besides the display and/or cable is bad? VERY recent (when display only partially gone) hardware diagnostics run and they said all was OK. Suggestions??
Update (01/12/2021)
Sorry. Tried Command-F1 and it didn't switch to TV. TV is Panasonic Plasma, NOT 4K.
Это хороший вопрос?
Ouch! Your display is cracked! What does the rest of the system look like is the case damaged or bent in any way?
из Dan
Case appears just fine; no dents or bends or misalignment. Glass over the display is NOT cracked.
из Robert
Your display is made up layers! The back glass layer is cracked not the top layer you can touch. The back layer is more fragile layer it doesn't like bangs or being twisted.
из Dan
