Model A2159, EMC 3301. A refresh of the entry-level 13" MacBook Pro. Available in Silver and Space Gray. Released July 2019.
103вопросов Показать все
Why is my power button not working?
Earlier this week a spilt a small amount of water (maybe 50ml) on my MacBook Pro 2019 (with TouchBar). It wouldn't turn on. Took it straight to a guy I know who got it to turn on and everything is now perfect apart from the power button.... It doesn't work. The Touch ID functionality works but I cannot use the button to turn my Mac on and off. For the moment I can wake it up from sleep with the keyboard but I am terrified that the Mac will switch off/run out of charge and I won't be able to get it back on again... What can I do? My MacBook is not under warranty.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Ouch! You are between a rock and a very hard place.
The TouchID button has two parts to it the power switch part and the finger print sensor. Sadly you need a new TouchID button! But replacing the button on your own will kill your system as the TouchID part is tied to the logic board logic.
Sadly you have no choice here you need to go to Apple to have them replace the TouchID button as they have the needed programer (which is not available to anyone outside of selected Apple repair depots.
Do you have AppleCare+ service contract? If you do that will help to take the sting of the repair costs.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
Thanks so much! Sounds like I am in a bit of a sticky situation... do you have any idea how much a repair will cost? I don't have AppleCare+ unfortunately... If it is super expensive I was thinking I could sell my Mac for parts and buy a new one - do you think someone will pay good money for it in this state?
из
The part its self is not difficult to get to or overly expensive alone. The only risk I can see here is if your logic board wetness detection sensors fired off then they could try to push you into replacing the logic board as well.
I would go to a real Apple Store they will do a free assessment giving you an estimate of the costs.
из
Cool, makes sense - thanks so much for your help!
из
Добавьте свой ответ
Hannah Davis будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 10
За всё время: 343
