Repair guides, support, and troubleshooting information for the first 13-inch MacBook Air to feature Apple's Arm-based M1 SoC (with an 8-core CPU and up to an 8-core GPU). Released in November 2020 and identified by model numbers A2337 or EMC 3598.
140вопросов Показать все
Any suggestions for making this dent disappear?
Hey everyone!
Unfortunately, I’ve managed to drop my macbook and now there is a dent on the back of the screen. The display is fully functioning, it just really hurts every time I look at it. Do you have any idea how to fix this without changing the whole display? I don’t want to do it DIY but is there any chance it can be fixed like car dents?
Pic:
I’ve worked really hard to finally buy it and now I feel terrible, I’m looking for a “budget-friendly” solution, but every answer is appreciated.
Thank you in advance
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
The problem with aluminum dents is they’re just there forever, especially on Retina models with how the assembly is built :(. Even when you can fix it, it’s still going to always be there.
You can sometimes remove the LCD from a non-Retina to improve the situation (albeit with some difficulty) but not on these - the bare LCD is bonded to the glass and the layers are in the aluminum shell.
Sad to say you’re buying a display or living with it.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thank you for the quick answer!
из
As a low budget solution you can get an external case/cover or a sticker to cover it up! Check here for ideas.
Оценка 2
1 Комментарий:
Smart idea! I've seen people with stickers on the back of their laptops so it won't look weird.
из
you can try with a bubble car puller!
Оценка 0
Добавьте свой ответ
Peter Tarr будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 49
За последние 30 дней: 184
За всё время: 3,454
