Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745вопросов Показать все
MacBook Pro doesn’t turn on after replacing keyboard
The period (.) button wasn’t work on my MacBook Pro Mid 2009 so I decided to replace the keyboard with one I purchased on Amazon. Once I replaced it with the new keyboard, the MacBook Pro doesn’t turn on. All the cables are connected, but once I connect MagSafe adapter, the battery indicator turns on but doesn’t let me SMC. How can I get my MacBook Pro to turn on again.
P.S. it was working before I replaced keyboard.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
There are a few possibilities here!
Are you sure you fed the ribbon cable into the logic board connector correctly and fully? Did you flip the latch down so the cable is compressed? Review this guide MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement Step 12. I find a piece of electricians tape can help in guiding the cable in using it as a pull tab. Make sure you don’t damage the latch?
Are you sure you got the correct keyboard for your system? MacBook Pro Unibody (A1278) Keyboard
MacBook Pro Unibody (A1278) Keyboard Изображение
Продукт
$19.99
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Chris будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 16
