Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455вопросов Показать все
How to Remove a broken ribbon cable head?
So I was trying to do a teardown of my 3ds, just to do some cleaning. I got to the motherboard and didn’t understand how to properly remove the ribbon cable, which lead to the head of the cable breaking off into it’s socket. Any ideas of how to remove it safely so I can add a new cable? If you’re wondering it’s the 3ds R button that is the problem. Thanks in advance :)
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
You can try with some thin tweezers. Start on the sides that DO NOT have the pins connecting to the motherboard. From the orientation on your picture, that would be left and right, not up and down. It should come out fairly easy.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks a bunch! >-<
Now to wait for the new part.
из
Добавьте свой ответ
Chase S будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 131
