installed new ifixit battery and showing no charge
I installed a new iFixit battery on my MacBook and it is showing as no charge. MagSafe charge is showing orange, but if the unplugged computer shuts down. I have tried all the troubleshooting recommendations with no luck.
Update (02/16/2021)
Thanks, Dan. Sorry for the confusion. I have a real Apple charger. It is the original that came with the Macbook when I purchased it. I guess my question is, this happened right after I installed the new battery. Is there something I could have done in the process to create the problem?
Это хороший вопрос?
6 Комментариев
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
из Dan
Thank you. attached a picture!
из Ben Boeving
Did you practice good ESD protection? Static electricity can damage MOSFET's. Winter time is always tricky! As the humidity within the air can be quite low which can make things worse!
из Dan
Since I am not really aware of ESD protection, I am going to say probably not. I am guessing that is not a good thing?
из Ben Boeving
True its not good ;-{
Again lets get the basics done first! Did you clean the MagSafe connector on your system make sure the grim is all cleaned out on the plastic and contacts.
из Dan
Показать 1 больше комментариев
