bottom RAM slot MBP 2012 13" gets very hot; shuts down at 95 degrees
I upgraded memory to 16 Gb and 512Gb SSD. I have cleaned laptop thoroughly, so no residual dust. Laptop sensor shows temperature rapidly rising when using any browser or video, shuts down at 95 deg. C. If only 8Gb in Slot 0, the temp gets to about 82 deg. C. medium usage; if in Slot 1 only, temp climbs to about 90-92 deg. C. I would really like to use 16 Gb since I run W10 in a virtual machine also. When both slots filled, temp hits 93 deg. rapidly. Is there anything I can do?
Update (02/20/2021)
i don’t know how to post the image better than this.
Update (02/20/2021)
I wasn’t expecting such a quick response. Thank you all.
@lemerise. I thank you for pointing out the pad over the ram slot. it isn’t there on this laptop. But your advice is well taken. I will simply use 8Gb. I had thought of putting thermal paste just below Slot 1 (where I think the pad was), but on second thoughts, I will make do with 8Gb RAM. Thank you for your assistance.
@Dan. TG Pro is paid software, I found. In any case, I have decided to settle for 8Gb RAM. Thank you.
Regards. Oladim
Это хороший вопрос?
Install this great app TG Pro please post a screenshot so we can see all of the sensors (you'll likely need to resize the window to get them all in one snap Adding images to an existing question
из Dan
@oladim - The tryout/test version is all you need! To post us a view on what's happening.
из Dan
