How to wipe out my school stuff and restart everything
Completely remove school development systems
Это хороший вопрос?
Это хороший вопрос?
This is not the first time this has come up, and I’ve covered it before. Back in school, I was able to grab printer IP addresses, bypass the web filter and make a deal with the admin department because they were tired of fighting me. See this answer for my expanded take on this: My chromebook has an admin on it, how do I remove it?. IT DOES NOT WORK.
The Chromebook remote management is tied to the device serial number, so you need to replace the board or contact the company who put the management on to remove it since it will always be there otherwise without a new board. In addition to that, post “CR-48” Chromebooks are patched against the CLI serial number swap, so in order to change the serial number you need to know how to do board reworking, own a flash programmer and how to program in hex. In addition to that, some of them encrypt or protect it in such a way you can’t practically change it or it wipes the chip if you try.
Был ли этот ответ полезен?
ahaha that first part happened to me too. now I help them make it harder to do that and am doing something like an internship. Of course, it was my own laptop. good luck trying to do that with a school issued device.
@some_aspy Yep. Then they wonder why it's harder and then realize it's the generation who cut the deals and got it done who know what doesn't work.
I haven't tried to reprogram the EEPROM on a post CR-48 since you're risking the entire machine when you can usually resolve it by contacting the admin who did it.
if the school provided you with the laptop you should NOT try to wipe it or remove their configuration.
Don't bother trying to use common sense with the people who want to try - they don't listen. They don't always listen to the technical version of why either. Yes, I know it may seem like I'm encouraging them to try by saying I got it done to outsiders, but I mention it to put my response into context and back it up with experience.
The kind of remote management we have today isn't the kind I defeated in high school.
@nick also, I don't know if you know it's me, but I used to go by captainsnowball :p had to purge a lot of stuff and update stuff because someone tried to doxx me.
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 17
За всё время: 52
