Speaker mount disconnected from main board
Hello,
I was replacing the speakers in my Mac Air. When I was trying to disconnect the speaker wiring from the socket on the main board, the entire socket came up, not just the speaker connection. See step 6 on the following page:
MacBook Air 13" Mid 2013 Left Speaker Replacement
My question is can I use conductive adhesive to glue the socket back onto the main board? Something like silver conductive epoxy adhesive?
Thanks
Это хороший вопрос?
Оценка 0
1 Комментарий:
It's best to post a few pics so we can see the damage. Take one of the connector base and the location of the connector would be mounted on the logic board.
Do make sure they are not blurry Adding images to an existing question
As far as conductive glue or epoxy that would not work, you really need a fine soldering iron or hot air station.
Lets see what you have before we go into what's needed here.
из
Добавить комментарий
