Dash Lights not working when Headlights are on
I have a 2001 Honda Accord DX and when I turn my headlights on, there are no backlight on the dash and I have replaced the fuse #10 on the passenger side hoping that would fix it but it didn’t help the situation. My taillights still work, parking lights, everything on the outside works but not my dash lights and I’m stuck.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @bunny23 ,
Have you tried adjusting the instrument panel dimmer control, you didn’t say?
(click on image to enlarge for better viewing)
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
I have tried that, the brightness was all the way up already and it still wasn’t working.
из
@bunny23
The best that I can find out for your model is that the dimmer switch is part of the instrument panel pcb board so the whole board would have to be removed to access it.
Of course it could also be the bulbs in the panel itself but once you have the pcb board you can check them
из
Добавьте свой ответ
Kaitlyn Crandall будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 696
