iPhone 7 plus keeps on crashing when making or receiving calls
Just recently replaced the broken screen on an iPhone 7 plus, and it seemed to be working fine, but now whenever I make a call or answer a call the phone crashes/reboots. For a while I was able to make calls by switching to speakerphone quickly, but now even that doesn’t work and it’s still crashing. I assume it’s an issue with the proximity sensor module ribbon cable connector, but I’ve disconnected it and reconnected it a couple of times, and even tried cleaning it out with alcohol to no avail (also the front facing camera works fine)
Это хороший вопрос?
what battery did you swap your original battery with
из Keshawn Vasugan
