Connects to PC without iTunes- immediately disconnects with iTunes.
NONE OF THE FIXES SUGGESTED ON ANY FORUM OTHER WORK FOR ME. THIS IS A WEIRD PROBLEM.
I have a 4th Generation iPod Nano in that nice purple blue color (no black spot yet, hooray!)
When I connect it to my PC without iTunes running, it connects fine. I can edit all of the files, bingo-bango-bongo it’s good there.
Now, when I have iTunes running, the iPod immediately syncs and disconnects within a second.
Again, I’ve browsed every other forum out there. It isn’t my USB ports. Not my computer. Not my cable. iTunes syncs to all of my other iPods just fine.
Is it just a problem with my Nano? It would be a real shame since it is in mint condition.
Это хороший вопрос?
Оценка 0
3 Комментариев:
I’m going to guess that it is an issue with the nano.
из
I don't know why though
It worked fine like a month ago
I'll have to take it apart (Oh boy, what a difficult one too)
из
I have a 1st gen iPod touch with close to the same issue. Instead of ejecting it says there was an error and to consolt an apple store or something. It worked at some point, there were movies and songs on it so I know it worked. What do you bet they would tell me if I went to a store?
из
Добавить комментарий
1 ответ
You may have to replace the motherboard, due to a problem with the connector. If you follow the guide on how to replace the motherboard, you should be able to get it working again. It does require soldering, though. While you’re in there, replace the battery so the infamous black spot doesn’t get it! Regards, TAG2YT
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
先生CherryPepsi будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 29
