Home button Only Responding Sometimes
I have a iPhone 5c that the home button has been working fine on.. but recently when I opened the phone and put it back together. The reason why I opened the phone is because the cable for the lcd came loose. If you were wondering. Afterwards the home button when I did a hard reset, aka holding the home and power button, the phone turned on. However, when I press the home button to unlock the phone, it no longer works. I would be sort of ok with it because I was able to enable assistive touch. However if the home button stops working completely I want to know what to replace. Also the home button itself can be removed without taking the phone apart. Which is not normal. I have had it fall out of its place without me doing anything, which it did not do before.
Это хороший вопрос?
Оценка 0
Комментарии:
And yes I will replace the screen on it... it is cracked and the lcd's cable does not want to stay connected. I do not have the plates on to protect it from doing that but it is way to loose that I dont think I could put the plate on without it falling off...
из
Добавить комментарий
