With many of these older (or low end) HP laptops the bare panel can be enough to total out the computer to the point you either need a donor, or end up replacing the entire computer. In some cases, the donor is better than the original in a good way where you give up on the original. I’ve personally have often ended up with donors that are so good, the original is being retired instead and the parts I need to move get moved evn though that wasn’t the intention. The cost issue isn’t AS MUCH of a problem if you have junk PCs you can pull a panel from (or time), but not everyone has that, or the specs rule out the long haul game. That said, the HP Spare# for this is L52000-001.
Take the laptop apart and make sure it’s the same before you order anything, but I’d bet on Samsung LTN or AUO for the LCD brand, or Innolux for some of the newer SVA machines (like my 840 G3’s FHD panel). It’s new enough to be eDP, but you probably want to double check.
Unless she has some emotional attachment to the laptop, the displays tend to total low end units like this one out unless you know how to shop for cheap parts, sad to say. The CPU (R5 3300U) and screen (768p EDP TN) give it away. This is coming from someone who called a laptop a family member clinged to a total loss, and had to tell her I will not work on it anymore after the dog went to the bathroom on it!
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
