Can't fix horizontal line after cable replacement.
(Toshiba LCD 50l2333d)
The problem I have is similar to this one:
https://it.ifixit.com/Risposte/Visualizz...
There is a permanent horizontal line that divides the screen in half and every 2/3 seconds the image double itself on the bottom half. I tried to follow the “duct tape method” with the ribbon cable of the T-CON and it got better but the black line still remains permanent. So i ordered the replacement cables and tried to replace the old ones but nothing changed. Should i order the whole T-Con board (already found it online) or there is something more that i could try? Thanks guys
Это хороший вопрос?
What is the condition of the actual connector on the TCON board? Are there any bent pins?
из honakrisi
Everything seems fine to me, no bent pins. I honestly thought that the problem was in the cables because when i added tape to the left one it got better:
https://ibb.co/2cQ1JKD
из Antonio
