Does not turn on
I was given this nice 17" MBP from 2007 (a1229). It has no battery, no charger and it is in an "unknown" state. I have 60W MagSafe 1 charger, so I tried to see if I can boot it, before I commit to buy a new charger and the battery. Spoiler: no success :(
What are the symptoms:
- Small white led in the middle always off (from what I read online, it should be blinking, at least sometimes)
- When charger is plugged in, the charger’s led is steady green
- I did the power on trick (hold power button for 10 sec, plug the charger, continue holding for 10 sec, release the power and press again) -> The fans are spinning like crazy (expected), the dvd does the regular sound of checking whatever, and I hear the chime, but no image on the screen. It does not turn on.
- Caps lock light does not work. So, keyboard is dead?
What should I do next?
Is it completely dead?
Why does the white led always off?
Am I must to use 85W adapter to boot it without the battery?
Any other checks I could do to determine the issue?
Thanks!
Это хороший вопрос?
1 Комментарий
On the battery you have a battery checker, when you press the button do all of the LED's light and are steady?
из Dan
